mdgm-ntgr
Sep 25, 2012NETGEAR Employee Retired
OwnCloud add-on thread
This is a general discussion thread for the OwnCloud add-on Owncloud for Sparc (Duo/NV+ v1 etc.): http://www.readynas.com/forum/viewtopic.php?f=47&t=66762 Owncloud for ARM (Duo/NV+ v2): http://www...
NickC1
Nov 02, 2012Aspirant
I just bought/installed the Readynas sparc addon with ownCloud 4.07. GUI looks fine, if slightly sluggish on the underpowered sparc but no surprise there. Uploaded some files, all ok.
I downloaded the sync client (Win7 x64).
After some minutes ( and a successfule sync) I got this message
"ownCloud Server Mismatch: The configured server for this client is too old."
Then the sync client exits. Had a few less graceful exits too from the sync client.
I can't see any older sync clients on the owncloud website. If you are thinking of trying this, and you want to sync with a local folder, I recommend you wait to see if a v4.5.1 or later addon appears.
[ EDIT: this is wrong, see the next couple of posts ]
Nick.
Nick.
