mdgm-ntgr
Sep 25, 2012NETGEAR Employee Retired
OwnCloud add-on thread
This is a general discussion thread for the OwnCloud add-on Owncloud for Sparc (Duo/NV+ v1 etc.): http://www.readynas.com/forum/viewtopic.php?f=47&t=66762 Owncloud for ARM (Duo/NV+ v2): http://www...
BadBrad
Nov 03, 2012Aspirant
Hi Nick,
I noticed on the own cloud site, that there are sync clients for both the newer and older versions. The site claims sync client 1.05 should be used for older versions like 4.0x. Here is the link I found: http://owncloud.org/sync-clients/ . Was the 1.05 client the one you were using?
--Brad
--Brad
