mdgm-ntgr
Sep 25, 2012NETGEAR Employee Retired
OwnCloud add-on thread
This is a general discussion thread for the OwnCloud add-on Owncloud for Sparc (Duo/NV+ v1 etc.): http://www.readynas.com/forum/viewtopic.php?f=47&t=66762 Owncloud for ARM (Duo/NV+ v2): http://www...
WSJ
Jan 05, 2013Tutor
Well, I've followed the instructions on slobberbone's website - and successfully updated my OwnCloud installation.
Since my previous installation did not contain a "data" subdirectory, I did not create the symbolic link; this was the only deviation from slobberbone's instructions. Ah, and yes - I did specify a different hostname since owncloud-latest.tar.bz2 is not really the latest version (I did use owncloud-4.5.5.tar.bz2 instead).
Maybe slobberbone could provide some insights (in English, please - on the website there are some French explainations but I'm unable to translate them) on the necessity to create the symlink.
Cheers, Wolfgang
Cheers, Wolfgang
