mdgm-ntgr
Sep 25, 2012NETGEAR Employee Retired
OwnCloud add-on thread
This is a general discussion thread for the OwnCloud add-on Owncloud for Sparc (Duo/NV+ v1 etc.): http://www.readynas.com/forum/viewtopic.php?f=47&t=66762 Owncloud for ARM (Duo/NV+ v2): http://www...
fastfwd
May 19, 2013Virtuoso
pugilares wrote: Will this work with the latest owncloud, which is at the moment 5.0.6?
You don't want to run Owncloud 5 yet. Wait for more bugs to be fixed; it's really unstable at the moment.
pugilares wrote: So, do I need to istall owncloud 4.0.7 from the readynasxtras package and then update?
Yes. Install the addon, then update using Slobberbone's instructions.
It's often recommended that, for safety, you update to the latest version of a release before upgrading to a later release. If you want to do that, install the 4.0.7 addon and make sure that it works, then update to 4.0.15 (the latest 4.0.x), then update again to 4.5.11 (the latest 4.x).
I prefer to update by entering the commands in Slobberbone's guide by hand, one by one, rather than running them all in a script. You'll need to customize the wget command with the correct download location for each version; the download locations for 4.0.15 and 4.5.11 are on the OwnCloud forum in the Announcements section: https://forum.owncloud.org
And speaking of the forum... Spend some time browsing through it; there's lots of information there.
Good luck.
