mdgm-ntgr
Sep 25, 2012NETGEAR Employee Retired
OwnCloud add-on thread
This is a general discussion thread for the OwnCloud add-on Owncloud for Sparc (Duo/NV+ v1 etc.): http://www.readynas.com/forum/viewtopic.php?f=47&t=66762 Owncloud for ARM (Duo/NV+ v2): http://www...
fastfwd
May 25, 2013Virtuoso
BTS wrote: I assume that this is a typo in slobberbones update instructions:
cp -Rn ../owncloud_save/apps/ ./
since there is no "-n" option for cp...
The GNU version of cp accepts the -n option; it means "do not overwrite existing files". Slobberbone used it on that line to prevent the script from erroneously overwriting updated versions of built-in apps with the older versions from your previous installation.
