mdgm-ntgr
Sep 25, 2012NETGEAR Employee Retired
OwnCloud add-on thread
This is a general discussion thread for the OwnCloud add-on Owncloud for Sparc (Duo/NV+ v1 etc.): http://www.readynas.com/forum/viewtopic.php?f=47&t=66762 Owncloud for ARM (Duo/NV+ v2): http://www...
christi1
Jun 15, 2013Aspirant
Hi
I have been trying to manually install owncloud 5 on my NV+ v2 (arm). I can get this to work with the exception of user authentication. There's a suggestion on the owncloud forums that this is because the frontview apache install uses authtype basic authentication, which interferes with owncloud's own authentication. Adding "Satisfy Any" to the apache config for the owncloud directory as suggested there doesn't seem to help.
Does anyone know the correct way to configure frontview apache to enable owncloud to work multi-user?
Thanks.
Thanks.
