mdgm-ntgr
Sep 25, 2012NETGEAR Employee Retired
OwnCloud add-on thread
This is a general discussion thread for the OwnCloud add-on Owncloud for Sparc (Duo/NV+ v1 etc.): http://www.readynas.com/forum/viewtopic.php?f=47&t=66762 Owncloud for ARM (Duo/NV+ v2): http://www...
WSJ
Jul 12, 2013Tutor
I'm currently running OwnCloud 5.0.5 on my Duo - and it works fine.
I've tried to update to 5.0.8 but that's causing the following "Fatal PHP" error:
Did anyone experience the same and managed to fix it?
ReadyNAS Duo (v1) with RAIDiator 4.1.12
PHP Version 5.3.17-0rnx1
XCache Version 2.0.1
xcache.admin.enable_auth = On
http://forum.owncloud.org/viewtopic.php?f=23&t=13382 makes me believe that 5.0.8 is buggy - should better wait for 5.0.9
xcache_clear_cache(): xcache.admin.user and/or xcache.admin.pass settings is not configured. Make sure you've modified the correct php ini file for your php used in webserver. at /usr/share/owncloud/lib/util.php#853
