mdgm-ntgr
Sep 25, 2012NETGEAR Employee Retired
OwnCloud add-on thread
This is a general discussion thread for the OwnCloud add-on Owncloud for Sparc (Duo/NV+ v1 etc.): http://www.readynas.com/forum/viewtopic.php?f=47&t=66762 Owncloud for ARM (Duo/NV+ v2): http://www...
MontyJ
Jul 18, 2013Aspirant
I just installed the only available OwnCloud version I saw that was available through the add-ons on the Netgear site. However, the 4.0.4 version is about a year old, and a newer one for ARM is available, 4.0.16, according to OwnCloud support.
Is there install manager for that version, ie is there a .bin file I can download and install over the current year old version? OwnCloud said I could do a manual install, but not sure how to go about that on the ReadyNAS Duo V2.
Anyone have a link for the newer file, or a procedure I can use to manually install the newer version into the Duo?
Thanks!
Montyj
Thanks!
Montyj
