mdgm-ntgr
Sep 25, 2012NETGEAR Employee Retired
OwnCloud add-on thread
This is a general discussion thread for the OwnCloud add-on Owncloud for Sparc (Duo/NV+ v1 etc.): http://www.readynas.com/forum/viewtopic.php?f=47&t=66762 Owncloud for ARM (Duo/NV+ v2): http://www...
fastfwd
Jul 19, 2013Virtuoso
MontyJ wrote: Anyone have a link for the newer file, or a procedure I can use to manually install the newer version into the Duo?
See the answer I just posted to your question on the Owncloud forum:
https://forum.owncloud.org/viewtopic.php?f=3&t=13566&p=35171#p35171
