alouch47
Sep 16, 2010Guide
PHP VirtualBox Manager (Help)
Hi all. "WhoCares?" if you're around, maybe you can help me with this. I've installed you addon and once made it works, but by the time VB wasn't working. (VB installed trough APT) Now that my...
WhoCares_
Sep 16, 2010Mentor
The reason for this problem is that VirtualBox changed the auth system for connecting to VirtualMachines but didn't reflect that change in vboxwebsrv. Thus, authentication will always fail unless a new Version of VitualBox fixes this.
For References see here: (vboxwebsrv authentication problem)
The only "solution" so far is to disable VirtualBox's internal auth by doing
Of course this will leave the barn door wide open, so you may want to play with .htaccess and friends like outlined here. (Authentication System)
-Stefan
VBoxManage setproperty websrvauthlibrary null
-Stefan
