alouch47
Sep 16, 2010Guide
PHP VirtualBox Manager (Help)
Hi all. "WhoCares?" if you're around, maybe you can help me with this. I've installed you addon and once made it works, but by the time VB wasn't working. (VB installed trough APT) Now that my...
alouch47
Sep 16, 2010Guide
WhoCares? wrote:
Of course this will leave the barn door wide open, so you may want to play with .htaccess and friends like outlined
-Stefan
Thanks for the info.
Just to be sure I understand correctly : If the device is in a LAN with a firewall and nothing is forwarded to the box, there is no particular risk ?
