alouch47
Sep 16, 2010Guide
PHP VirtualBox Manager (Help)
Hi all. "WhoCares?" if you're around, maybe you can help me with this. I've installed you addon and once made it works, but by the time VB wasn't working. (VB installed trough APT) Now that my...
InTheShires
Jan 06, 2012Tutor
Probably a stupid question, and a simple solution to boot, but the the hey!
Are people using phpVirtualBoxManager to manage their VM's?
I've got VBox 4.18.xxx, (latest) installed, running, booting, and a quick test VM of Ubuntu that I can view and via a remote desktop. (Basic Windows one for the time being)
I've had phpvboxmgr work successfully just once. And when I say successful, I just mean I could see the VM.
After that, I've not been able to use the phpvboxmgr app. I get a constant stream of errors. (See end of post for some of the most repeated msgs.)
I've tried adjusting things here and there with tips posted here, and elsewhere. (WebAuth = Null, .htaccess file, user/pass. ETC, ETC.)
I'm using WhoCares? PHPVBoxMgr_0.4-readypro-0.1.1.bin addon. Same errors mostly.
So, I've grabbed the latest file via the official site. I've tried running that. which also gives me a headache and won't get me a working PHP Vbox Manager.
Ultra 2+.
Firmware 4.2.17
Stock RAM
WhoCares? PHP addon installed, which seems to be fine with SOAP accrding to the page, which I believe has been an issue in earlier releases.
I've spent 3 days and evenings on this, and I just cannot get it working. :(
Errors! Enjoy!!!
Any finally...
Ultra 2+.
Firmware 4.2.17
Stock RAM
Errors! Enjoy!!!
Exception Object
[message:protected] => Could not connect to host
[string:Exception:private] =>
[code:protected] => 32
[file:protected] => /frontview/ui/resource/html/phpvboxmgr/lib/vboxconnector.php
[line:protected] => 111
[trace:Exception:private] => Array
[0] => Array
[file] => /frontview/ui/resource/html/phpvboxmgr/lib/vboxconnector.php
[line] => 1749
[function] => __vboxwebsrvConnect
[class] => vboxconnector
[type] => ->
[args] => Array
[1] => Array
[line] => 218
[function] => getVMsCached
[type] => ->
[args] => Array
[0] => Array
[fn] => getVMs
[1] => Array
[data] =>
[errors] => Array
[persist] => Array
[2] => Array
[file] => /frontview/ui/resource/html/phpvboxmgr/lib/ajax.php
[line] => 93
[function] => __call
[type] => ->
[args] => Array
[0] => getVMs
[1] => Array
[0] => Array
[fn] => getVMs
[1] => Array
[0] => Array
[data] =>
[errors] => Array
[persist] => Array
[3] => Array
[line] => 93
[type] => ->
[args] => Array
[0] => Array
[fn] => getVMs
[1] => Array
[0] => Array
[data] =>
[errors] => Array
[persist] => Array
[previous:Exception:private] =>
Exception Object
[0] => Array
[line] => 1808
[type] => ->
[args] => Array
[1] => Array
[line] => 218
[function] => getMediumsCached
[type] => ->
[args] => Array
[0] => Array
[fn] => getMediums
[1] => Array
[data] =>
[errors] => Array
[persist] => Array
[2] => Array
[line] => 93
[type] => ->
[args] => Array
[0] => getMediums
[1] => Array
[0] => Array
[fn] => getMediums
[1] => Array
[0] => Array
[data] =>
[errors] => Array
[persist] => Array
[3] => Array
[line] => 93
[type] => ->
[args] => Array
[0] => Array
[fn] => getMediums
[1] => Array
[0] => Array
[data] =>
[errors] => Array
[persist] => Array
Exception Object
[0] => Array
[line] => 2622
[type] => ->
[args] => Array
[1] => Array
[line] => 218
[function] => getSystemPropertiesCached
[type] => ->
[args] => Array
[0] => Array
[fn] => getSystemProperties
[1] => Array
[data] =>
[errors] => Array
[persist] => Array
[2] => Array
[line] => 93
[type] => ->
[args] => Array
[0] => getSystemProperties
[1] => Array
[0] => Array
[1] => Array
[0] => Array
[data] =>
[errors] => Array
[persist] => Array
[3] => Array
[line] => 93
[type] => ->
[args] => Array
[0] => Array
[1] => Array
[0] => Array
[data] =>
[errors] => Array
[persist] => Array
Any finally...
phpVirtualBox
Method 'ns1:ISystemProperties_getMaxVDISize' not implemented: method name or namespace not recognised
Details...
