alouch47
Sep 16, 2010Guide
PHP VirtualBox Manager (Help)
Hi all. "WhoCares?" if you're around, maybe you can help me with this. I've installed you addon and once made it works, but by the time VB wasn't working. (VB installed trough APT) Now that my...
InTheShires
Apr 27, 2012Tutor
j6harri wrote: InTheShires,
Were you ever able to get this working. I am getting the exact same errors?
I get it working in the end and it's still working now, I just need to upgrade the RAM on it, to optimise things a little.
That said, I can't remember exactly what I did. "jmalmlund" kindly PM'd me out the blue with some advice which, IIRC pointed me in the direction to get things moving again. Unfortunately I can't remember exactly what I did. I think I resorted to reinstalling VBox and the EXT pack, which solved much of my problems, although I tried so many things I lost track of what I did. Also, IIRC, I also had to call vboxwebsrvr manually, and then created a script to start it at reboot. There were also some AUTH issues which I seem to recall struggling with, but jmalmlund's PM helped me with that.
I had no joy making any VBox stuff work on anything other than v4.2.17 firmware. Though I think some have succeeded with a beta of 4.2.20 Txx
