mode500
Sep 16, 2014Aspirant
PhpMyAdmin & MysqlOn Problems
Hi all :D This is my first post here so go easy with me ... OK I've recently bought a second hand ReadyNAS Duo V1 and am trying to get it up & running as a web server to use wordpress on. I ha...
mode500
Sep 17, 2014Aspirant
Hi, first of all thank you so much for the reply!
Yes, that is correct, using the login 'root' and leaving the password field empty does not work! I have been trying to follow the work around here http://www.readynas.com/forum/viewtopic.php?f=36&t=72799 and here http://www.linuxquestions.org/questions/linux-newbie-8/can't-login-to-phpmyadmin-819842/ but I am totally confused by it as I am not sure where I am supposed to be looking for the files, and how?
Thank you once again :)
