mode500
Sep 16, 2014Aspirant
PhpMyAdmin & MysqlOn Problems
Hi all :D This is my first post here so go easy with me ... OK I've recently bought a second hand ReadyNAS Duo V1 and am trying to get it up & running as a web server to use wordpress on. I ha...
Sep 17, 2014Guru - Experienced User
/etc is on the OS partition. You enable ssh to access it, and use something like putty.
Once there, you either
-use vi, or
-copy it to the data partition, and edit it with an editor like notepad++ which preserves linux formatting (not notepad). Then copy it back with ssh when done.
You enable ssh by installing the sparc binary of the enablerootssh add-on here: http://www.readynas.com/?p=4203
-use vi, or
