mode500
Sep 16, 2014Aspirant
PhpMyAdmin & MysqlOn Problems
Hi all :D This is my first post here so go easy with me ... OK I've recently bought a second hand ReadyNAS Duo V1 and am trying to get it up & running as a web server to use wordpress on. I ha...
Sep 17, 2014Guru - Experienced User
Are you able to log into the ReadyNAS with iterm? If you can, the try entering
The NAS has a data partition on the disks, which is where the shares are. There's a second partition which contains the linux operating system and the NAS software - a 2 GB partition on your NAS.
vi is a command line text editor that is often used by linux folks. You probably won't like it much (I don't).
cd /etc/phpmyadmin
ls -l
