mode500
Sep 16, 2014Aspirant
PhpMyAdmin & MysqlOn Problems
Hi all :D This is my first post here so go easy with me ... OK I've recently bought a second hand ReadyNAS Duo V1 and am trying to get it up & running as a web server to use wordpress on. I ha...
Sep 17, 2014Guru - Experienced User
Ok. That means the directory exists. Otherwise you'd get
-bash: cd: /etc/myphpadmin: No such file or directory
and if you then enter "ls -al" you only see the files . and .. ???
