mode500
Sep 16, 2014Aspirant
PhpMyAdmin & MysqlOn Problems
Hi all :D This is my first post here so go easy with me ... OK I've recently bought a second hand ReadyNAS Duo V1 and am trying to get it up & running as a web server to use wordpress on. I ha...
mode500
Sep 17, 2014Aspirant
StephenB wrote: Ok. That means the directory exists. Otherwise you'd get
-bash: cd: /etc/myphpadmin: No such file or directory
and if you then enter "ls -al" you only see the files . and .. ???
See the files where!?!
In terminal I still only get a reply of '>
And in iTerm (Mac's Putty equivalent) I do get a return of -bash: cd: /etc/phpmyadmin: No such file or directory
