mode500
Sep 16, 2014Aspirant
PhpMyAdmin & MysqlOn Problems
Hi all :D This is my first post here so go easy with me ... OK I've recently bought a second hand ReadyNAS Duo V1 and am trying to get it up & running as a web server to use wordpress on. I ha...
Sep 17, 2014Guru - Experienced User
Ok. Are you sure you are actually logged into the NAS with both iterm and terminal???
For instance, if you enter
do you see the shared folders on the NAS
cd /c
ls -l
