mode500
Sep 16, 2014Aspirant
PhpMyAdmin & MysqlOn Problems
Hi all :D This is my first post here so go easy with me ... OK I've recently bought a second hand ReadyNAS Duo V1 and am trying to get it up & running as a web server to use wordpress on. I ha...
mode500
Sep 17, 2014Aspirant
mdgm wrote: That shows your GRANT share.
To see the contents of the GRANT share you could do e.g.
# ls -la /c/GRANT
or look recursively using e.g.
# ls -laR /c
Woohoo!!! FINALLY got somewhere with the second command and it brought up this amongst other things :
/c/webroot:
total 48
drwxr-xr-x 3 admin admin 16384 Sep 7 2008 .
drwxrwxrwx 9 root root 16384 Sep 7 2008 ..
drwxr-xr-x 11 admin admin 16384 Dec 15 2010 phpadm
/c/webroot/phpadm:
total 2608
drwxr-xr-x 11 admin admin 16384 Dec 15 2010 .
drwxr-xr-x 3 admin admin 16384 Sep 7 2008 ..
-rw-r--r-- 1 admin admin 10829 Nov 29 2010 browse_foreigners.php
-rw-r--r-- 1 admin admin 4354 Nov 29 2010 bs_change_mime_type.php
-rw-r--r-- 1 admin admin 1797 Nov 29 2010 bs_disp_as_mime_type.php
-rw-r--r-- 1 admin admin 2368 Nov 29 2010 bs_play_media.php
-rw-r--r-- 1 admin admin 798 Nov 29 2010 calendar.php
-rw-r--r-- 1 admin admin 11519 Nov 29 2010 ChangeLog
-rw-r--r-- 1 admin admin 3565 Nov 29 2010 changelog.php
-rw-r--r-- 1 admin admin 473 Nov 29 2010 chk_rel.php
-rw-r--r-- 1 admin admin 1854 Dec 15 2010 config.inc.php
-rw-r--r-- 1 admin admin 2162 Nov 29 2010 config.sample.inc.php
drwxr-xr-x 3 admin admin 16384 Nov 29 2010 contrib
-rw-r--r-- 1 admin admin 234 Nov 29 2010 CREDITS
-rw-r--r-- 1 admin admin 1458 Nov 29 2010 db_create.php
-rw-r--r-- 1 admin admin 10415 Nov 29 2010 db_datadict.php
-rw-r--r-- 1 admin admin 2336 Nov 29 2010 db_export.php
-rw-r--r-- 1 admin admin 537 Nov 29 2010 db_import.php
-rw-r--r-- 1 admin admin 27435 Nov 29 2010 db_operations.php
-rw-r--r-- 1 admin admin 7389 Nov 29 2010 db_printview.php
-rw-r--r-- 1 admin admin 30581 Nov 29 2010 db_qbe.php
-rw-r--r-- 1 admin admin 13120 Nov 29 2010 db_search.php
-rw-r--r-- 1 admin admin 980 Nov 29 2010 db_sql.php
-rw-r--r-- 1 admin admin 25353 Nov 29 2010 db_structure.php
-rw-r--r-- 1 admin admin 7277 Nov 29 2010 db_tracking.php
-rw-r--r-- 1 admin admin 3404 Nov 29 2010 docs.css
drwxr-xr-x 3 admin admin 16384 Nov 29 2010 documentation-gsoc
-rw-r--r-- 1 admin admin 246242 Nov 29 2010 Documentation.html
-rw-r--r-- 1 admin admin 173318 Nov 29 2010 Documentation.txt
-rw-r--r-- 1 admin admin 2243 Nov 29 2010 error.php
-rw-r--r-- 1 admin admin 25308 Nov 29 2010 export.php
-rw-r--r-- 1 admin admin 18902 Nov 29 2010 favicon.ico
-rw-r--r-- 1 admin admin 15614 Nov 29 2010 import.php
-rw-r--r-- 1 admin admin 1077 Nov 29 2010 import_status.php
-rw-r--r-- 1 admin admin 6789 Nov 29 2010 index.php
-rw-r--r-- 1 admin admin 137 Nov 29 2010 INSTALL
drwxr-xr-x 3 admin admin 16384 Nov 29 2010 js
drwxr-xr-x 2 admin admin 16384 Nov 29 2010 lang
drwxr-xr-x 11 admin admin 16384 Nov 29 2010 libraries
-rw-r--r-- 1 admin admin 18011 Nov 29 2010 LICENSE
-rw-r--r-- 1 admin admin 453 Nov 29 2010 license.php
-rw-r--r-- 1 admin admin 13369 Nov 29 2010 main.php
-rw-r--r-- 1 admin admin 27220 Nov 29 2010 navigation.php
-rw-r--r-- 1 admin admin 27617 Nov 29 2010 pdf_pages.php
-rw-r--r-- 1 admin admin 53336 Nov 29 2010 pdf_schema.php
-rw-r--r-- 1 admin admin 421 Nov 29 2010 phpinfo.php
-rw-r--r-- 1 admin admin 1079 Nov 29 2010 phpmyadmin.css.php
drwxr-xr-x 5 admin admin 16384 Nov 29 2010 pmd
-rw-r--r-- 1 admin admin 9845 Nov 29 2010 pmd_common.php
-rw-r--r-- 1 admin admin 1866 Nov 29 2010 pmd_display_field.php
-rw-r--r-- 1 admin admin 18504 Nov 29 2010 pmd_general.php
-rw-r--r-- 1 admin admin 829 Nov 29 2010 pmd_help.php
-rw-r--r-- 1 admin admin 3762 Nov 29 2010 pmd_pdf.php
-rw-r--r-- 1 admin admin 3994 Nov 29 2010 pmd_relation_new.php
-rw-r--r-- 1 admin admin 1973 Nov 29 2010 pmd_relation_upd.php
-rw-r--r-- 1 admin admin 2071 Nov 29 2010 pmd_save_pos.php
-rw-r--r-- 1 admin admin 1063 Nov 29 2010 print.css
-rw-r--r-- 1 admin admin 8252 Nov 29 2010 querywindow.php
-rw-r--r-- 1 admin admin 2571 Nov 29 2010 README
-rw-r--r-- 1 admin admin 758 Nov 29 2010 README.VENDOR
-rw-r--r-- 1 admin admin 29 Nov 29 2010 RELEASE-DATE-3.3.8.1
-rw-r--r-- 1 admin admin 26 Nov 29 2010 robots.txt
drwxr-xr-x 2 admin admin 16384 Nov 29 2010 scripts
-rw-r--r-- 1 admin admin 7584 Nov 29 2010 server_binlog.php
-rw-r--r-- 1 admin admin 2641 Nov 29 2010 server_collations.php
-rw-r--r-- 1 admin admin 15336 Nov 29 2010 server_databases.php
-rw-r--r-- 1 admin admin 4689 Nov 29 2010 server_engines.php
-rw-r--r-- 1 admin admin 1615 Nov 29 2010 server_export.php
-rw-r--r-- 1 admin admin 549 Nov 29 2010 server_import.php
-rw-r--r-- 1 admin admin 98602 Nov 29 2010 server_privileges.php
-rw-r--r-- 1 admin admin 2893 Nov 29 2010 server_processlist.php
-rw-r--r-- 1 admin admin 16986 Nov 29 2010 server_replication.php
-rw-r--r-- 1 admin admin 565 Nov 29 2010 server_sql.php
-rw-r--r-- 1 admin admin 22147 Nov 29 2010 server_status.php
-rw-r--r-- 1 admin admin 59483 Nov 29 2010 server_synchronize.php
-rw-r--r-- 1 admin admin 2196 Nov 29 2010 server_variables.php
drwxr-xr-x 4 admin admin 16384 Nov 29 2010 setup
-rw-r--r-- 1 admin admin 297 Nov 29 2010 show_config_errors.php
-rw-r--r-- 1 admin admin 26786 Nov 29 2010 sql.php
-rw-r--r-- 1 admin admin 8175 Nov 29 2010 tbl_addfield.php
-rw-r--r-- 1 admin admin 7214 Nov 29 2010 tbl_alter.php
-rw-r--r-- 1 admin admin 54171 Nov 29 2010 tbl_change.php
-rw-r--r-- 1 admin admin 9781 Nov 29 2010 tbl_create.php
-rw-r--r-- 1 admin admin 2573 Nov 29 2010 tbl_export.php
-rw-r--r-- 1 admin admin 700 Nov 29 2010 tbl_import.php
-rw-r--r-- 1 admin admin 7954 Nov 29 2010 tbl_indexes.php
-rw-r--r-- 1 admin admin 2435 Nov 29 2010 tbl_move_copy.php
-rw-r--r-- 1 admin admin 28458 Nov 29 2010 tbl_operations.php
-rw-r--r-- 1 admin admin 16521 Nov 29 2010 tbl_printview.php
-rw-r--r-- 1 admin admin 23511 Nov 29 2010 tbl_relation.php
-rw-r--r-- 1 admin admin 15613 Nov 29 2010 tbl_replace.php
-rw-r--r-- 1 admin admin 4825 Nov 29 2010 tbl_row_action.php
-rw-r--r-- 1 admin admin 16239 Nov 29 2010 tbl_select.php
-rw-r--r-- 1 admin admin 919 Nov 29 2010 tbl_sql.php
-rw-r--r-- 1 admin admin 31967 Nov 29 2010 tbl_structure.php
-rw-r--r-- 1 admin admin 25306 Nov 29 2010 tbl_tracking.php
drwxr-xr-x 4 admin admin 16384 Nov 29 2010 themes
-rw-r--r-- 1 admin admin 1253 Nov 29 2010 themes.php
-rw-r--r-- 1 admin admin 196 Nov 29 2010 TODO
-rw-r--r-- 1 admin admin 1625 Nov 29 2010 transformation_overview.php
-rw-r--r-- 1 admin admin 3674 Nov 29 2010 transformation_wrapper.php
-rw-r--r-- 1 admin admin 9076 Nov 29 2010 translators.html
-rw-r--r-- 1 admin admin 4569 Nov 29 2010 user_password.php
-rw-r--r-- 1 admin admin 5368 Nov 29 2010 view_create.php
-rw-r--r-- 1 admin admin 1132 Nov 29 2010 webapp.php
