LrdShaper
Apr 29, 2009Aspirant
Privoxy Add-on v1.0 (ReadyNAS NV+/NV/Duo/1100/600/X6)
Privoxy Add-on for ReadyNAS sparc devices - a non-caching web proxy with advanced filtering capabilities for enhancing privacy, modifying web page data and HTTP headers, controlling access, and removi...
LrdShaper
Jul 19, 2009Aspirant
It's up. Get it from http://devrandom.blogsite.org/projects/ ... n_1.01.tar
Since Privoxy's Web front-end, can not be controlled separately by "ACLs" or HTTP authentication, everybody who can access Privoxy can modify its configuration for all users.
So I decided to get creative but too many distractions popped-up today but here's the end result:
From here you can toggle the enable-edit-actions option so that Privoxy's Web UI will let you modify the values in the config file.
On another note, I cannot find the button to edit the 1st post
