james_mediaflee
Feb 14, 2012Aspirant
Problems downloading ReadyNAS Photos 2.0 RC1
Hello, I'm having problems downloading the Windows version of ReadyNAS Photos 2.0 RC1 using the link in this post http://www.readynas.com/forum/viewtopic.php?f=58&t=28567.
Can anyone help please?
Thanks James
Thanks James
- mdgm-ntgrNETGEAR Employee RetiredSo since you're looking for Photos I software, I guess you have a NV+ v1 (How to tell whether I have a Duo v1 or Duo v2 or NV+ v1 or NV+ v2)?
http://www.readynas.com/downloadsNetGear wrote:
ReadyNAS Photos I Desktop Software
If you’ve enabled ReadyNAS Photos option in Frontview, you will need the ReadyNAS Photos Desktop software to export photos to the ReadyNAS from your PC, Mac, or Linux system. The link for this software is available from Frontview.
Welcome to the forum! - james_mediafleeAspirantHi mdgm,
Yes I have the NV+ v1 model.
I've managed to download the photos software via the Frontview link, but after installing it, it says it's version 1.1?? I was hoping to install version 2.0 so that I could organise my photo albums alphabetically.
Regards - mdgm-ntgrNETGEAR Employee RetiredConsidering that Photos I is being EOL'd (http://www.readynas.com/forum/viewtopic.php?f=58&t=60875), I guess they've pulled the non-production software
- james_mediafleeAspirantYea, I feared this. Guess I'll just have to use what I've got.
- minervaAspirantHello all,
We apologize for the inconvenience caused.
We have identified issues with downloading ReadyNAS Photos 2.0 RC1 and have fixed it.
Can you please try downloading the software ones again.
-Minerva. - james_mediafleeAspirantDownload link is now working. Thanks
- alistairburchAspirantDear Sir
I get the following error from the Frontpage View link
The requested URL /cas/install/ReadyNASPhotosInstallerWithJava.exe was not found on this server. - StephenBGuru - Experienced UserPhotos II isn't available on a duo v1 anyway. Is that what you have? (if your firmware is 4.1.x you have a v1, 5.x.x is the v2).
- ReadySECUREApprenticeStephenB is correct. alistairburch, please check if your unit is v1 or v2. If it is v2, please update this post.
RND2000v2.
