james_mediaflee
Feb 14, 2012Aspirant
Problems downloading ReadyNAS Photos 2.0 RC1
Hello, I'm having problems downloading the Windows version of ReadyNAS Photos 2.0 RC1 using the link in this post http://www.readynas.com/forum/viewtopic.php?f=58&t=28567.
Can anyone help please?
Thanks James
Thanks James
- mdgm-ntgrNETGEAR Employee RetiredWhat does How to tell whether I have a Duo v1 or Duo v2 or NV+ v1 or NV+ v2 indicate you have?
Some v1 units had a sticker on them with a "v2". Confusing I know but at that time NetGear presumably wasn't planning to release a new product called a Duo/NV+ v2. - alistairburchAspirantDEar Sir - mine says RND2000v2 on the unit - so I presume v2.
- alistairburchAspirantThe REady NAsS Frontview links to the following page
http://www.readynasphotos.com/cas/install/ReadyNASPhotosInstallerWithJava.exe - StephenBGuru - Experienced User
Don't presume, check using the link above. Regrettably you cannot trust the label on the unit.alistairburch wrote: DEar Sir - mine says RND2000v2 on the unit - so I presume v2. - mdgm-ntgrNETGEAR Employee RetiredOnly the v1 would link to that software as Photos II (the version of ReadyNAS Photos on the Duo v2) is completely managed via the web browser. So you must have a Duo (v1). Photos I (the version of ReadyNAS Photos installed on the Duo v1) is EOL'd.
- alistairburchAspirantBased on the LInk and the "soft" check and the "hard" check, I would appear to have the v1.
- alistairburchAspirantSo if I have v1 and Frontview has a link to ReadyNas photos that is EOLifed - have I been sold a dud?
- StephenBGuru - Experienced UserNot sure its a "dud" exactly. It has a lot of features that are still missing on the duo v2 - though it is slower, and as you point out, it doesn't support the new Readynas photos 2.
If you exchange it, the models to look at are the ultra/ultra plus/pro 2 and the duo v2. I like the ultra/ultra plus/pro lines myself. - nolesrbAspirantI have version Firmware 4.1.8. From what I am reading, that means that I cannot use the Photo functionality. Is there another way I can use this device to share photos with family members that are not close by?
- pit78AspirantSorry I don't know if Im right on this topic but I couldn't find a better matching.
Accidentally I deleted Photos from my RND2000 and am desperate to find one to download.
Can anyone please help me?
Thank you so much in advance :worship:
