Etz
Aug 06, 2012Aspirant
PyLoad not starting
PyLoad addon suddenly fails to start.
When trying to start it manually, it gives lots of errors.
Probably not compatible with Python 2.7? :roll:
But it ran fine just until I rebooted the unit, due to re-locating.
Unfortunately I dont have a clue, where to get Python 2.6 addon now, to roll back to older version
20:33:05-root@NAS:/usr/bin$ python pyLoadCore
06.08.2012 20:33:10 INFO Starting pyLoad 0.4.9
06.08.2012 20:33:10 INFO Using home directory: /c/.pyload
Traceback (most recent call last):
File "pyLoadCore", line 666, in <module>
File "pyLoadCore", line 657, in main
File "pyLoadCore", line 391, in start
File "/usr/share/pyload/module/plugins/PluginManager.py", line 50, in __init__
self.createIndex()
File "/usr/share/pyload/module/plugins/PluginManager.py", line 73, in createIndex
self.plugins["hooks"] = self.hookPlugins = self.parse("hooks")
File "/usr/share/pyload/module/plugins/PluginManager.py", line 196, in parse
temp = self.parse(folder, pattern, plugins)
File "/usr/share/pyload/module/plugins/PluginManager.py", line 163, in parse
config = literal_eval(config[0].strip().replace("\n", "").replace("\r", ""))
File "/usr/share/pyload/module/lib/SafeEval.py", line 44, in const_eval
c = test_expr(expr, _const_codes)
File "/usr/share/pyload/module/lib/SafeEval.py", line 33, in test_expr
raise ValueError, "%s is not a valid expression" % expr
ValueError: ("activated", "bool", "Activated", True), ("key", "str", "Key", ""), ("force", "bool", "Force CT even if client is connected", False), __author_name__ = ("RaNaN") __author_mail__ = ("RaNaN@pyload.org") SUBMIT_URL = "http://bypasscaptcha.com/upload.php" RESPOND_URL = "http://bypasscaptcha.com/check_value.php" GETCREDITS_URL = "http://bypasscaptcha.com/ex_left.php" def setup(self): self.info = {} def getCredits(self): json = getURL(BypassCaptcha.GETCREDITS_URL % {"key": self.getConfig("key")}) response = loads(json) if response[0 is not a valid expression
- EtzAspirantOK, removing it manually via SSH and Re-installin did the trick, still wondering what possibly could cause such a behaviour.
- puchetecaAspirantHey i am having the same problem but eventhough i am removing the plug i keep getting zhe same error, how do you rtemove the add on manually=?
- EtzAspirantSSH into your readynas, navigate into /etc/frontview/addons and execute PYLOAD.remove script... ;)
Then reboot the unit...and re-install addon via frontview.
