ilkevinli
Mar 15, 2012Aspirant
Change Twonky port ?
Hi, Does anyone know of a way to change the port that Twonky uses ? I have a security system that uses port 9000 so I need to change the Twonky port to something else. Thanks.
ilkevinli
Mar 16, 2012Aspirant
I figured it out and here is how to do it for those that might need to do it.
1. Login to the ReadyNAS via SSH
2. Browse to the twonkymedia folder located at /c/
3. Download the twonkymedia-server.ini file and open it with wordpad or notepad
4. Make the changes, save it, and overwrite the old file (Make sure you keep a backup of the original)
