mtjoernelund
May 13, 2011Aspirant
Re-install ReadyNAS Photos does not re-create database
After a lot of problems with ReadyNAS Photos I decided to remove the add-on from my NAS and re-install it, hoping this could help me start the process of album creation etc. all over. However it seems...
mtjoernelund
May 16, 2011Aspirant
minerva wrote: Presently there is no such script file which can create individual tables on ReadyNAS Photos, the only way is to re-install add-on which will create all the tables
Can you please detail us the actual problem because of which you reinstalled the add-on
-Minerva
Problem is that I have re-installed the add-on several times and the tables does not get recreated. So as of now I have no way of using ReadNAS Photos, as I cannot recreate the necessary entries in the SQL database.
The problems I had was several, corrupted albums, missing resized pics, missing thumbnails, persons that had received invitations that did no longer work etc.
I was actually quite happy to start over as I had learned how to use the add-on, so could start without the errors I have made before. But now I just can't start at all...
