mtjoernelund
May 13, 2011Aspirant
Re-install ReadyNAS Photos does not re-create database
After a lot of problems with ReadyNAS Photos I decided to remove the add-on from my NAS and re-install it, hoping this could help me start the process of album creation etc. all over. However it seems...
minerva
May 23, 2011Aspirant
We have verified the log file and could see that the dekoh user is not present in your mysql database. For a factory-fitted ReadyNAS add-on, installation should create the user,database and tables, no separate script to run.
Though unable to reproduce the issue at my setup, to help you out, can you please tell us if you have done any modifications to your database/tables prior to the installation of add-ons.
As a work around, try re-installing the add-on once more and see if the issue gets fixed at your setup.
-Minerva
-Minerva
