mtjoernelund
May 13, 2011Aspirant
Re-install ReadyNAS Photos does not re-create database
After a lot of problems with ReadyNAS Photos I decided to remove the add-on from my NAS and re-install it, hoping this could help me start the process of album creation etc. all over. However it seems...
InTheShires
Jun 30, 2011Tutor
minerva wrote: I have verified the log files and could see that your ReadyNAS Photos database configuration is invalid. To correct this, I recommend re-installing the add-on".
ReadyNAS photos add-on can be downloaded from http://www.readynas.com/?cat=36.
Installing software phpMyAdmin is known to interfere with ReadyNAS Photos functioning by making changes to Database users configuration.
Did you install phpMyAdmin ?
Thanks,
-Minerva.
I've tried reinstalling the addon, but I get this...
Uploaded with ImageShack.us
I've redownloaded, to make sure it's not corrupt. I've also used a different browser, but it gives the same error message.
Yes, I do have PHPMyAdmin installed, which is needed. I did disable it while trying to install the Sparc Photos2.2.bin, but I still got the same error message.
Thank you.
