Annamarie
Jul 06, 2017Aspirant
No Users Found - RemoteNAS
Really need some help!!! Have a Netgear NAS NV+ and have been running RemoteNAS successfully for years. Performed an update a few weeks back. End user informed me she was unable to connect via Rem...
JennC
Jul 10, 2017NETGEAR Employee Retired
Hello Annamarie,
Do you not see this same window?
Posting a screenshot with covering personal details (SN, WAN IP, email address) will help.
Annamarie
Jul 10, 2017Aspirant
- ErikHuiJul 11, 2017Tutor
Hi Annamarie, it's under Advanced settings, in the lower left corner when Remote Access is open.
- AnnamarieJul 11, 2017Aspirant
Here is the screen capture you requested.
Also, I have been reading other Forum posts about this error. They recommend deleting certain root configuration files. Can we do that? How do I do that? Can someone share how that is done? Can a moderator do this?
Thank you!
I think you're referring to https://community.netgear.com/t5/Legacy-NETGEAR-and-Partners-Add/ReadyNAS-Remote-quot-User-not-found-quot-Problem/m-p/875341?
Putty/SSH instructions:
- download+install putty
- connect to ip-address of NAS with root user/pass using connection type SSH
- navigate to folder /opt/ (cd /opt/)
- delete p2p folder (rm -rf p2p)
Tried this earlier myself to no avail :(
- JennCJul 11, 2017NETGEAR Employee Retired
Hello ErikHui and Annamarie,
I will try to check this with other as I also got the same error on 2 different legacy units.
I will get back to you as soon as I get an update.
- YeZJul 14, 2017NETGEAR Expert
There was a security vulnerability issue fix on the remote server, that has caused R4/R5 legacy devices to not work with ReadyNAS Remote.
The data on the NAS is not affected at all, only remote access is not available. Unfortunately while we look into this, there is no easy solution without the security fix to re-enable R4/R5 support.
- ErikHuiJul 14, 2017Tutor
Thanks for the update, glad you found the root cause. Can you please give a (rough) timeline for this?
Thanks,
Erik - ErikHuiJul 19, 2017Tutor
Can we have an update on this issue please? Thanks!
- AnnamarieJul 21, 2017Aspirant
Hello,
Any status on progress for restoring these services?
My client is dependent on this resource and business processes are greatly impacted.
Thank you.
Annamarie
- ErikHuiAug 31, 2017Tutor
Wow, more than a month has passed without an update. Come on Netgear...
- portiahAug 31, 2017Aspirant
I am getting exactly the same problem and would like a fix too asap.
- mfinneySep 28, 2017Apprentice
Any update from anyone on this - I still have this problem. Can Netgear confirm the issue is fixed their end?
- mperreySep 28, 2017Tutor
Netgear has decided to terminate the ReadyNAS Remote service instead of fixing the problem:
I posted a message requesting they make ReadyCLOUD service available on legacy NAS units. At present, it only works on newer NAS units. They haven't replied.
Mark
- mfinneySep 29, 2017Apprentice
mperrey, really appreciate your response. Disappointing to see Netgear leaving a large and loyal customer base in this position at such short notice. Appreciate product necessarily have a finite support lifespan, but would have exected at least a year's notice for business class products or a much more comprehsive proactive cumminication like Microsoft et al...
Many thanks
- andershlOct 23, 2017Aspirant
So this explains why my NGO is experiencing that same error and has received the highly discouraging Remote-end-of-life notice. Highly disappointing. Must find another vendor next time.
- mdgm-ntgrOct 23, 2017NETGEAR Employee Retired
It has been a number of years now since the last product that didn’t ship with ReadyNAS OS6 was discontinued.
