shireeshj
Jun 26, 2017Aspirant
ReadNas 314 Timemachine backups stopped ReadyNAS 314
I have been using ReadyNAS for taking private timemachine backups and it was running smooth for several months. The backups stopped happening in the last week of May. I have been trying to figure ou...
JennC
Jun 28, 2017NETGEAR Employee Retired
Hello shireeshj,
Are you saying you cannot get to the NAS volume via AFP? Maybe you want to try connecting the NAS straight to the computer and then run RAIDar to see its current IP address so you'll know what IP subnet to manually assign to the computer.
Welcome to the community!
shireeshj
Jun 30, 2017Aspirant
It is certainly not the IP address issue. I can use the NAS with "SMB shared folders" without any issues. But Timemachine uses AFP, and that is where I have the problem.
- JennCJun 30, 2017NETGEAR Employee Retired
- shireeshjJul 10, 2017Aspirant
Tried upgrading to 6.7.5
It does not fix the problem.
- btaroliJun 30, 2017Prodigy
shireeshj wrote:It is certainly not the IP address issue. I can use the NAS with "SMB shared folders" without any issues. But Timemachine uses AFP, and that is where I have the problem.
Have you tried to create a regular share using AFP and connect to that, apart from TimeMachine?
Tried creating an AFP share... but it does not allow me to create one. the error message is "Failed to create share. Please verify that the share name is valid and unique" Code 101305001
I am using plain text (alphabets only, without any spaces) for the share name, which works for an SMB share. Also verified that the name is unique. So I dont think the error message is accurate
- btaroliJul 10, 2017Prodigy
It also can't match any hidden shares created by the NAS for its own purposes. You didn't mention what name(s) you tried, but avoid "timemachine". ;) But if you're unable to do this then it lijkeoy something's messed up in the config files related to AFP.
