ssurba
Dec 19, 2012Guide
Transmission 2.82 for ReadyNAS DUO v2/NV+ v2 (ARM) – FREE
Hi Everyone, this is the discussion thread for Transmission 2.82 for ReadyNAS DUO v2/NV+ v2 (ARM) add-on. Add-on thread is here: http://www.readynas.com/forum/viewtopic.php?f=147&t=70426&p=39078...
ssurba
Feb 19, 2013Guide
Hi Cosmos,
thank you for your detailed input.
"prefetch-enabled" and "utp-enabled" config parameters were set to default values and I did not change them.
I'll try to get more info about POSIX_FALLOCATE function and maybe try to disable it, if possible.
But from my point of view, if you are not copying/deleting/moving files on your NAS very often, fragmentation should not be an issue. I would not bother about it at all. :-)
Your request on including transmission-remote client is accepted, I will include it in next build.
Cheers, Sergey!
Cheers, Sergey!
