ssurba
Dec 19, 2012Guide
Transmission 2.82 for ReadyNAS DUO v2/NV+ v2 (ARM) – FREE
Hi Everyone, this is the discussion thread for Transmission 2.82 for ReadyNAS DUO v2/NV+ v2 (ARM) add-on. Add-on thread is here: http://www.readynas.com/forum/viewtopic.php?f=147&t=70426&p=39078...
ssurba
Apr 24, 2013Guide
super-poussin wrote: did you compile with --disable-nls --enable-lightweight --enable-largefile ?
Hi super-poussin,
I've compiled with --enable-lightweight only.
I did not want to disable NLS, because there could be files with national characters in names.
It seems that support for large files is enabled by default and as far as I know there is no option --enable-largefile in ./configure (as of v.2.77).
Regards, Sergey!
