shireeshj
Jun 25, 2017Aspirant
ReadNas 314 Timemachine backups stopped ReadyNAS 314
I have been using ReadyNAS for taking private timemachine backups and it was running smooth for several months. The backups stopped happening in the last week of May. I have been trying to figure ou...
btaroli
Jun 29, 2017Prodigy
Well, I think I can safely rule out compatibility issues as the source of the trouble. I've been using 6.7.x with macOS 10.12.x (now 6.7.5 and 10.12.5) without issue. It sounds like you're using per-user Time Machine volumes, where in my case I've stuck with a global one. So I can't help you on that part, but that's probably where I'd focus my attention in diagnosing this further... the actual TM setup on the NAS.
What does the Mac actually say (if you have the TM preferences panel up when you attempt a backup)? Could it just be the password? I had this happen to me once (pre 6.7) when I had to reset my TM password on the NAS side and then reconnect. But perhaps it's something more. Hard to say with the info in hand.
