Murphy73
Apr 20, 2021Follower
ReadyNas 2304 6.10.4
Does this model (2304 FW- 6.10.4) support RSA2/SHA256 (new version of OpenSSL support)?
- Apr 22, 2021
Hi Murphy73,
Welcome to the Community!
No, it does not support it. The ReadyNAS uses OpenSSL from May 2016.
JohnCM_S
Apr 27, 2021NETGEAR Employee Retired
Hi Murphy73,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as a solution so others can be confident in benefiting from the solution.
The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
