linkup1's avatar
linkup1
ReadyNAS Connectivity issues
It will not allow me to enter my model number ReadyNASRNDP6000. Suddenly the other day I couldn't connect to the RN.  No errors on the console, seemed fine, but I couldn't connect through a drive m...
  • StephenB's avatar
    Jul 01, 2018
    linkup1 wrote:
    Your suggestion seems more of a software fix?
    Yes.  I am assuming that something is mildly corrupted in the OS, leading to a memory leak or some similar condition.
    It could also be something hardware related - a failing PSU can give a wide range of symptoms.  But most hardware issues should be giving you some alerts in the logs (temperature alerts, rising SMART error counts, etc).
ProSupport for Business
