acalvo's avatar
acalvo
Star
Feb 23, 2009
ReadyNAS Duo & Twonky
Hello!
Recently, I bought a Netgear ReadyNAS Duo and I´m very interested in install Twonky Media Server on my ReadyNAS. However, I didn´t find any detailed information about the install this software in the Duo. And...my question is:
Can I install Twonky Media Server in Duo with the add-on in this link for the ReadyNAS NV/X6/600?
Thanks!!
  • I've just ordered a Duo (haven't received it yet). And I have the same basic questions as Acalvo.
    From what I can observe in the forums, there are references to the Duo with Twonky. I am guessing that the code for the ReadyNAS 600, X6, NV/NV+, 1100 is the right one. But I do not see any direct mention of the Duo.
    Actually, it would be great to have a small up to date matrix of the available/recommended versions of Twonky per ReadyNAS server (including the different links).
    Tx.
  • FYI: super-poussin is the reference concerning twonky on ReadyNas.
  • Merci à super-poussin pour la précision. J'ai reçu et installé mon Duo. Je commence à me familiariser et à tester.
  • Hello, I have downloaded and installed Twonky on the Duo however it saysits expired and I am required to obtain a registration key. Can you let me know where and how I get this? do i need to purchase it from Twonky?
    Yes the license is managed by twonky
    http://www.twonkymedia.de/store/index.aspx
  • Hello.
    I also want to buy the license of Twonky for my ReadyNAS DUO v1.
    In the website there are two options: Twonkey Manager (including Twonkey Server) and Twonkey Server.
    What license should I buy to use on my ReadyNAS DOU?
    THANK YOU VERY MUCH.
  • I too have a ReadyNas Duo v1 and my twonky server (the latest supported on Duo v1 by super-poussin) is 6.0.38. I went to the twonky website and they had options for older license keys (4.x-5.x) and the new software 7.x but nothing listed for purchasing a license key for 6.x version. I sent them an email asking them about this. I will let you know what I hear back.
  • Just wanted to update all of you. The license keys for version 7.x works with 6.x versions. Show when you go to their website, just purchase a 7.x license key.
ProSupport for Business
