Fleecypaws
Oct 17, 2017Aspirant
ReadyNAS Duo 1 Logitech Server Issue
Hi there to all, I’m getting a bit of a headache with an issue regarding the Logitech Server on my ReadyNAS Duov1. The problem is that I can see all the files (all music) but when I log in to t...
- Oct 29, 2017
Hello Fleecypaws,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance. If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Marty_M
NETGEAR Community Team
Marty_M
Oct 23, 2017NETGEAR Employee Retired
Hello Fleecypaws,
What version of logitech media server addon is installed on the NAS and do you have readydlna addon installed? Can you attach a screenshot of the error message when you try to do a rescan.
Marty_M
Fleecypaws
Oct 23, 2017Aspirant
Hi there Marty_M,
Thanks for taking the time to reply.
When i log on to the settings page of LMS and try to do a rescan media/music files it simply won't respond at all although i can close the page down so i'm a bit confused. I import my CD's as normal then do a rescan and although i can see the file it wont play becasue i can't rescan. I can can reboot the NAS and it does a scan but that dosen't solve the problem. I think i'm running 7.7.5. I can confirm that i don't get an error message just no response.
I hope the above made some kind of sense :-)
mike
- Marty_MOct 24, 2017NETGEAR Employee Retired
Hello Fleecypaws,
Please check the thread here appears to be similar to the problem you are encountering.
Marty_M
NETGEAR Community Team- Marty_MOct 29, 2017NETGEAR Employee Retired
Hello Fleecypaws,
Marty_M
