Pavelods
Mar 12, 2018Follower
ReadyNAS Duo/ Readynas photos
Hello Everyone! I have a problem with install Readynas Photos into my ReadyNAS Duo. System not accept Readynas Photos II.bin Error: The update file is not suitable for this architecture. Wher...
- Mar 12, 2018
Hi Pavelods
Welcome to the Community!
If you have a Duo V1 unfortunately Photos II is not compatible with it, You have to have a Duo V2 for it to come installed with the firmware.
if you have a V2 then make sure you update the firmware then try to install the add-on again.
Photos i which Duo V1 supports is already EOL, Click here for the info.
Hope this helps!
Regards
Marc_V
Mar 12, 2018NETGEAR Employee Retired
Hi Pavelods
Hope this helps!
Regards
Mar 12, 2018Guru - Experienced User
Marc_V wrote:
If you have a Duo V1 ...
Pavelods: You definitely have a v1. A Duo v2 runs 5.3.x firmware. A Duo v1 runs 4.1.x - and that is clearly what you are running.
So your NAS is not compatible with Photos II, and as Marc_V explains, you can't use Photos I either. Your best option is to look for a service that either runs on a cloud server or runs on a PC.
- mdgm-ntgrMar 12, 2018NETGEAR Employee Retired
In any case Photos II has been discontinued as well so even on models that supported that it can't be used anymore.
