Frankie3142
Jan 30, 2018Aspirant
ReadyNAS Duo (Sparc) needs SMBv2 or higher
Hi I have the ReadyNAS Duo V1 (Sparc). Since the Microsoft 2017 Fall Creator's Update for Win10, SMBv1 is obsolete and I can't see it anymore on my main Windows PC (although I can on a second, older...
Jan 30, 2018Guru - Experienced User
wrote:
Hi
I have the ReadyNAS Duo V1 (Sparc). Since the Microsoft 2017 Fall Creator's Update for Win10, SMBv1 is obsolete and I can't see it anymore on my main Windows PC (although I can on a second, older machine). It needs to support SMBv2 or v3. I read that this can easily be done by adding the line:
Let's start here. If you go into "turn windows features on and off" you should see an option for the SMB1 client. So you can still re-enable that option.
If you see an NFS client in your windows system, you could alternatively install that, and then turn on NFS file sharing on the NAS. That might be a better long-range solution.
Enabling an ancient experimental mode in your duo v1's SAMBA is probably not a good approach.
Frankie3142
Jan 31, 2018Aspirant
Hi
Unfortunately no option for turning on NFS is present. I should state that I'm using Windows Home edition (on the 2 PC's on my little 'network') so perhaps NFS is an option on the Pro or some other edition of Windows. Anyone aware of any 3rd party software I can get that might fix the issue and introduce NFS?
Meanwhile I have an interesting update. My older PC (call it PC1) has the so called Fall update of Windows 10 too, and yet it can still see, read and write to the ReadyNAS Duo as perfectly as ever. PC2 meanwhile (the newer hardware), cannot do anything - the NAS has become totally invisible inaccessible from there. Some people have found that creating a network connection using the IP address of the NAS gets around the problem, but that's not working for me. Having one PC see the NAS isn't quite the fix it first appears to be. Imagine my backup routine for PC2 now: backup PC2 to PC1 (assuming thee's enough space on the older machine. Then move the backup off PC1's disk to the NAS. That's looking like a 24 hour operation now.
Upgrading the NAS isn't quite an option either (I'm on a severely limited budget). I feel angry and let down by Netgear for not providing better support.
I appreciate your remarks (and those of others) on how the old experimental Samba mode isn't to be celebrated, but I may be looking at any port in a storm at this point. I'd still like someone to tell me how to access the shell I installed. Besides, if I could figure out how to access the shell I could do the text edit to the config referenced elsewhere in these forums and linked to in my original post I think. It would be an experiment itself. If it didn't work I could always back out of it and stick with the bizarre 'daisy chain' method of accessing it via PC1 as I seem condemned to do now anyway.
Thank you.
- SandsharkJan 31, 2018Sensei
Assuming the "shell" you installed is "Enable Root SSH Access", you need to install Putty on your PC. Use the default settings in Putty for an SSH connection and type in the NAS IP address. When the CLI opens, log in as "root" using the admin password.
But from there, you'll still need to know how to navigate the Linux file system and use VI to edit the file. Google can be your friend there. And, BTW, you will have to set the min protocol to SMBV2, as your NAS has no SMBV3 support. Given that SMBV2 is only experimental in your version of Samba, issues are possible.
But is enabling SMBV1 not an option in your Windows version?
Also, for NFS, open an elevated command line on the Windows machine and execute
dism /online /get-features | more
and see if these are listed:
Feature Name : ServicesForNFS-ClientOnly
State : DisabledFeature Name : ClientForNFS-Infrastructure
State : DisabledFeature Name : NFS-Administration
State : DisabledIf they are, you can use
dism /online /Enable-Feature:NFS-Administration
and repeat for all the above features to turn on NFS even though it's not listed in the enable features GUI. I don't have a Home version install to check on.
- Frankie3142Jan 31, 2018AspirantHi Sandshark
Thank you for your amazingly detailed response. You are a gentleman and a scholar! I just wanted to thank you ahead of trying your advice as I will be away from the PC's for nearly a week & so unable to try your suggestions, but I'll give you feedback on what happened in due course.
Thanks again! - BxD007May 26, 2018Aspirant
I just performed the NFS command line items, and it all seems to work now on my old NV+.
Question: Did I just open up the gates of hell, in terms of security holes on my PC, now that I did this?
Thanks,
BxD
- StephenBJan 31, 2018Guru - Experienced User
Enabling the SMB1 client in Windows should still be possible, and I recommend doing that instead of enabling the old experimental flag.
- grebApr 18, 2018Aspirant
Today got an error message on a Win 10 (32) bit that it can't access the Ready Nas Duo any more. I think we definitely need SMB2 support from Netgear for our Readynas devices. There was a message, that it was disabled from Microsoft because they are considering not secure any more and pronoe to ransomware attacks!
Please asist - thank you!
- mdgm-ntgrApr 18, 2018NETGEAR Employee Retired
The Duo was replaced in our product lineup way back in 2011. It's well beyond the security support period.
You could re-enable SMB1 support on your PC.
