kunalraiker
Jun 23, 2012Aspirant
ReadyNAS DUO Torrent Client
For the love of humanity, can someone recommend or help me fix one torrent client.I have both the default bit torrent and also transmission, but end up having constant issues with eh two where, as soo...
JarnoG
Jul 03, 2012Guide
It is very important you stop the Transmission service before you change any settings in the settings.json file. Also, try disabling the PEX, DHT and LPD services. This can be done both using the Transmission web gui as manually in settings.json
