b_i_l_l_y
Jan 06, 2025Aspirant
ReadyNas Duo v1 - Custom OS
I have an old ReadyNas Duo v1 with raid 0 (4tb - x2 2tb) that I want to use as a 3rd level backup location and has anyone installed a custom os on this NAS?
saudade
Jan 06, 2025Apprentice
I use mine as is. My primary NAS is a WD EX4 (4x2tb Raid 5, also EOL). I use my Duo (2x2tb Raid 1) to backup my EX4. I also have a USB drive connected to the Duo so once the EX4 is backed up, I run another set of backup jobs to write to the USB. My EX4 is also on a UPS.
My Duo is on a power schedule. So it fires up, runs the jobs, then powers down. Really "critical" files are also backed up to various cloud storage systems, so my important files are safe from anything short of an asteroid strike. If I have to bug out and have time to grab my bag, I can simply grab the USB.
- StephenBJan 06, 2025Guru - Experienced User
saudade wrote:
I use mine as is.
I also use mine as is. (FWIW as a third level backup of some shares). Mine is running two 2 TB JBOD volumes.
Like you, mine is running on a power schedule (as are my other backup NAS).
But truthfully, I keep my Duo (and my NV+) in service simply because they are still working ok (and because I figure you can never have too many backups). When they fail, I won't attempt to repair or replace them.
I also use cloud backup for disaster recovery.
- b_i_l_l_yJan 06, 2025Aspirant
Thanks for the info.
Has anyone installed a custom os on this NAS?
