ACrescendo
Nov 30, 2023Aspirant
Readynas duo v1 Access Problem because of user rights failure
Hello, I was adjusting some file owner rights on readynas duo with ssh connection.Mistakenly, ı have assigned a predefined user to all files as owner while ı am at the root. That messed the thing...
Sandshark
Dec 01, 2023Sensei
Have you tried an OS re-install? That should reset the rights to all the OS partition files and I would expect that to allow you to log in. I don't recall on a V1 whether an OS re-install then requires you to re-enable SSH.
Even if you had not made that mistake, messing with user permissions via SSH is a really bad idea. The ReadyNAS also maintains it's own databases, and making changes like that could create issues when the Linux permissions don't jive with what the database thinks they should be.
ACrescendo
Dec 01, 2023Aspirant
Os-reinstall , even with usb, didnt work, nothing happened. So ı will go with the Stephen B.'s solution, and check it works or not.
