ACrescendo
Nov 30, 2023Aspirant
Readynas duo v1 Access Problem because of user rights failure
Hello, I was adjusting some file owner rights on readynas duo with ssh connection.Mistakenly, ı have assigned a predefined user to all files as owner while ı am at the root. That messed the thing...
ACrescendo
Dec 01, 2023Aspirant
So, when ı remove disks, I should be sure that disks can be read by another software. Does raid mechanism break things?
Dec 01, 2023Guru - Experienced User
R-Linux (free) should work, assuming the Duo is using RAID-1/X-RAID or JBOD (two volumes, one on each disk). It only reads the disk, so everything on it remains intact even if you find it isn't working.
If you are using RAID-0 (one volume with no RAID redundancy) then you would need to use R-Studio (which is not free), or a similar product that supports RAID recovery and the EXT file system.
