ex06
Apr 09, 2024Aspirant
ReadyNAS Duo V1 problem installing SSH addon
I've just got my hands on ReadyNAS Duo V1 RND2000 (hardware v2) software version 4.1.16. I wanted to give it a little TLC ❤️ so it can be used with newer OSes. Found a guide that fixes SMB v2 com...
ex06
https://kb.netgear.com/24546/Add-ons-for-RAIDiator-4-1-3-Sparc
From this page, addon don't show on installed services page, nor putty have a connection to NAS
Apr 10, 2024Guru - Experienced User
That is the right add-on.
My recollection is that it is a "toggle" install - that won't show up on the services page. If you install it a second time, it will actually do an uninstall. If it's possible that you did that, then try installing it one more time.
Also, you do need to change the admin password to something other than the default netgear1.
