sillian1
Jan 30, 2017Aspirant
ReadyNAS Duo V1 RND2000 torrent speed
Hi to all, i have an issue with the torrent client speed of my NAS. First of all, here you can find the details about the configuration and firmware installed: Model: ReadyNAS Duo [X-RAID] ...
Jan 30, 2017Guru - Experienced User
Your old NAS is much slower than your PC. I don't know of any way to speed up your torrent add-ons.
- sillian1Jan 30, 2017Aspirant
Hi Stephen,
thanks for the answer, you mean that could be an HW limit of the NAS?
2mb/sec is not a very high speed, i can transfer file from the PC to the NAS at very high speed, so i have some doubt on the possibility of an HW limit.
- StephenBJan 30, 2017Guru - Experienced User
Yes I do. Your ReadyNAS uses very old and (by modern standards) slow sparc processor and has limited memory as well. There are several (mostly old) threads commenting on the poor speeds with transmission and bittorrent.
CIFS (and AFP) don't load the CPU of the NAS nearly as much as the torrent app does. Even there, a new entry level NAS has 3x the speed of the Duo v1.
