mladen5
Jan 01, 2022Aspirant
ReadyNAS Duo v2 - IP available but won't connect
Hi, I wonder if somebody would know how I can reaccess my readynas duo v2 again, all of the sudden I seem unable to connect to it. RAIDar shows that he status us "Healthy" with the one drive connect...
- Jan 02, 2022
Unfortunately it's the only disk. Nevertheless, I decided to cancel the R-Linux scan which still brought up a red "Rocognized0" volume. I right clicked on this to select "open drive files", and voila! I can view the files in the existing folder structure and recover only those I want to keep. I'll probably bin this one buy a more recent NAS which will hopefully be a tad more reliable.
Thanks for your help though, it is very much appreciated.
mladen5
Jan 02, 2022Aspirant
Jan 02, 2022Guru - Experienced User
Yes, harddiskVolume17 is the data volume. 15 is the OS partition, 16 is (I think) swap. Temporary, in any event.
It is an old NAS (became end-of-life in 2013).
But it looks to me like the issue here is actually the disk. In any event, the only way to protect against data loss is to back up the data to another device (RAID protection isn't enough, and of course you weren't using it anyway).
