cosmos1
Oct 12, 2012Aspirant
ReadyNAS Duo v2: apt-get and free P2P clients?
Hello all, before asking what I intented to ask, I wanted to provide a "feeling" of this unit: a brand new ReadyNAS Duo V2 unit, on which I installed a 2TB Samsung F4 in Flex-RAID/JBOD configuratio...
KydDynoMyte
Is the basic procedure to install a package with APT and then move it to another directory on the /c volume (to save memory) and then link from the old location to the new?
That is basically what I did to install ZNC on a Duo V2, then the new firmware upgrade seems to have broke it. Is there a better way so it survives a firmware upgrade? I had also changed my APT sources to wheezy instead of squeeze before installing ZNC.
Would doing an apt-get upgrade be a bad idea? I assume it would be bad whether it was pointing to squeeze or wheezy.
