cosmos1
Oct 12, 2012Aspirant
ReadyNAS Duo v2: apt-get and free P2P clients?
Hello all, before asking what I intented to ask, I wanted to provide a "feeling" of this unit: a brand new ReadyNAS Duo V2 unit, on which I installed a 2TB Samsung F4 in Flex-RAID/JBOD configuratio...
cosmos1
Oct 13, 2012Aspirant
mgdm wrote:
I repeat what I said above. APT is pre-installed on the ARM devices. So this means you can simply install EnableRootSSH (http://www.readynas.com/addons), login as the 'root' user (password initially set to 'admin' password) do an "apt-get update" then start installing stuff via apt.
OMG, I didn't read your previous post carefully! Thank you for clarifying this with me. I will avoid apt-get upgrade altogether, just an apt-get install for rtorrent and screen, carefully checking that no other files are overwritten, or installed, that might change behaviour.
You're awesome mate, thumbs up! If I succeed I'll try to share my experience here!
