cosmos1
Oct 12, 2012Aspirant
ReadyNAS Duo v2: apt-get and free P2P clients?
Hello all, before asking what I intented to ask, I wanted to provide a "feeling" of this unit: a brand new ReadyNAS Duo V2 unit, on which I installed a 2TB Samsung F4 in Flex-RAID/JBOD configuratio...
Etz
Oct 17, 2012Aspirant
cosmos wrote: I tried doing an apt-get install libtorrent, but it was not found. Of course I could try an apt-get update, but I have a bad feeling about it :) Do you believe that I could do a local install of libtorrent and rtorrent?
Apt-get update only updates package lists and doesnt break anything, apt-get upgrade instead will definately brick it, as lots of core libraries are being upgraded and so on...
Also extreme caution is advised if installing something from debian repos, as packages have dependencies and there is a risk of upgrading core libraries or just having "dependency hell" afterwards.
So you have to carefully work trough dependencies to avoid accidentally breaking ReadyNAS OS...
