alek91
Oct 18, 2013Aspirant
ReadyNas Duo V2 Python
Hi guys,
I have had a Netgear ReadyNas Duo V2 for a year now, and I would like to install python and pyload on it, but I do not understand at all how to do it. I'm using RAIDiator 5.3.8.
By the way, does PyLoad support Alldebrid accounts ?
Thanks if you can give me some hints :-)
- mdgm-ntgrNETGEAR Employee RetiredHere are some add-ons you could install: http://rnxtras.com/addons/category/readynas-os5-arm
- alek91AspirantHi,
Thanks to you, I installed pyLoad, but I can't understand how to add an hoster (plugin) to it. Can you explain to me please ?
I think I have to add the .py file over SSH with my mac but I don't know how to do it. I know how to connect to pyload with ssh using ssh root@ip address but not how to copy the file and where to copy the file.
Thanks ! - mdgm-ntgrNETGEAR Employee RetiredYou could copy the file using scp. If you have a URL to the file you may find it easier to download it using wget.
Or you could copy the file onto a share on the NAS using the Finder then SSH in and copy it to where it needs to go. - alek91AspirantYes but how to access the pyload part on the nas ?
- alek91AspirantHey guys,
I'd have a final question.
I'd like to check if my Nas is connected with a gigabit connection or 100 mbps.
How can I do that with the dashboard ?
Thanks !
